Acquire continuous waveforms from two channels on a scope
I want to acquire a continuous waveform on each separate channel on my scope, and to see each waveform on it's own graph.
I tried to do it, you can see the VI that I uploaded...
The problem is whan I run the VI - it works, but each graph refreshs in it's time and it doesn't happen simultaneously.
It's a problem because it creates a situation that I can loose a waveform because while one graph is refreshing the other one is not refreshing.
What can I do?
(4,258 Views)
You are using serial communication. This sort of communication is very slow. So I doubt you will not get much data in real time. You are probably only getting segments of the realtime curve.
Besides which, my opinion is that Express VIs Carthage must be destroyed deleted
(Sorry no Labview "brag list" so far)
(4,242 Views)
No, I use usb for the communication.
What can I do?
(4,211 Views)
You can't do anything. You are seeing a basic limitation of the instrument. Have you considered a pc scope card?
(4,200 Views)
Are you sure?
Because I think my scope is pretty good...
I have Tektronix TDS2024B, this is the datasheet: http://www.tequipment.net/pdf/tektronix/TDS2000B_datasheet.pdf
(4,153 Views)
Yeah, i'm sure. Have you read the manual? Have you found a command that transfers both channels at once? If you have, use that command.
(4,136 Views)
Yes, you are right.
Thanks...
(4,097 Views)
