Acquire data from a thermal couple device using RS232
This a sample Front Panel what I am actually looking for. I have attach this VI. The initialization is going to be a pop-up menu which would set appropriate setting for RS232 communication, once that is Ok, the green light would indicate that. The Channel button is also a pop-up menu which would let the user select the channel, with in this menu you have choices to select all 32 channel or check which channels needed. Also whinin this you have to provide file name which would save the data in Excel file and user would select the time rate to save the data i,e. every 1 minutes the one data will be saved. On the bottom I have made a sample log which would indicate the appropriate fields as seen in my VI. t
he location is a user input which sould be saved in EXcel file also.
Message 11 of 13
(577 Views)
This is log printed out from the device printer. I had two thermal couples connected on channel 1 and 2 and it shows up to 24 channels.
Message 12 of 13
(577 Views)
Hi Noman,
I am attempting to upload the documents you sent. I have experienced problems as well and will be looking into the problem.
As a workaround, it seems that changing the rich text formatted documents to word documents before zipping the file avoided the upload error.
thanks,
Eric Meyer
Discussion Forums Administrator
Message 13 of 13
(577 Views)
