Acquire data from two 9181 Ethernet modules in the same VI?
I have been running a field-deployed daq rig reading 1-3 channels of data on a single cDAQ module in a 9181 chassis and sending it to a laptop over an Ethernet cable.  I recently was asked to get 2 channels located at two different locations with a wireless link (over water).  In this configuration I'd have one 9181 located near my laptop with a hard connection through a switch and another located some distance away with a wireless bridge.
Synchronization is not really important as I'm really just trying to avoid having a separate person standing at the other location pressing record or having to deal with triggering (very different event signal levels).  I really just need two dumb data streams over Ethernet coming into the same VI (data producer/consumer loops).
In the Express task I can see both DAQ's, but when I select ai0 from one of them and ai0 from the other and try to run it, it throws an error and asks about an NI9469 module.  I can tell that it is looking for some of the more conventional triggering and sychro architectures, which aren't needed here.  I have previously gotten my VI to acquire data from a USB GPS device and a single cDAQ module and write to the same file with no problems despite very different sample rates.
I am still what I'd consider an entry-level user and programmer. Any input appreciated.
(2,577 Views)
Why are you putting both into the same express VI?
Since they are two different modules, create two different express VI's, one handling each module.
(2,545 Views)
