Acquire data using message queues
Hello!
I'm new to labview and I would like some help on a program I'm working on.
I need to acquire data from a queue. The queue has to push start or stop message/ audio and data should be acquired based on whether you receive start or stop. How do I go about this? Should I use a producer/consumer loop?
After acquiring the data it will be analysed and logged. The idea is to get audio/vibration measurements. I'm using the queue to push start/stop temporarily.
Thanks for your help!
Maddy
(5,027 Views)
Could you post your code so we can better understand your setup?  It sounds like you are already setup as a Producer/Consumer, which is why I am confused.
(5,013 Views)
Hi crossrulz
I don't have a code yet. Someone suggested using a producer/consumer loop. Do you have any example programs where you acquire data from a queue and log it. Sorry, I'm still figuring my way around LabVIEW.
Maddy
(5,005 Views)
Ok, let's take a step back.  What is the goal of your program?  Where is the data coming from?  How is the data being taken?  What format do you want the data saved?
(4,995 Views)
The goal of the program is to collect audio samples and log them. I'd like to include a graph/waveform to show the samples as they are acquired.
The data is coming in through a Plc to a cdaq(9132) and it has to be logged in a spreadsheet. The parameters for the audio samples haven't been set yet. I need to set up the data acquisition part first and I'm having trouble with coming up with the code.
Maddy
(4,989 Views)
Accepted by topic author Ben-Da-Nee
Are you using LabVIEW 2016?
If so, in this thread I shared what will be the new look of the producer/Consumer when making use of Channels.
I latter when on to share what a Channeled Message Handler
They may help you get started with the new channel wires and the design patterns that best meets your needs.
Ben
(4,984 Views)
Thank you Ben! I understood the part about using channels instead of queues, although the code itself was a little too complicated for me. I need to come up with a data acquisition vi whose input is in the form of a 2D floating point array. Could you help me with a simple frame? I have difficulty starting a code, I'm a hardware engineer and I'm really trying to get better at LV.
Thanks!
(4,899 Views)
