Acquire different types of analog signals with PCI-6221 and SCC-68
Hi,Properly an easy task, but for me it has already resulted in many frustrations, which I hope some of you can help me get rid of. The problem is that I have a pci-6221 and a SCC-68 and that I have to get some analog measurements triggered by a shaft encoder. From the shaft encoder I have a maximum of 2048 counts/s ( 2rpm ),  and every  time I get a trigger signal I want to measure the other analog signals ( 2 x temperature,  1 x strain and 2 x voltage). Until now I have tried to do this by a sequence in a for loop but this is not nearly fast enough to do this acquiresation, and it results in delayed measurements. (Something to do with CPU power I guess?)  I’m all new in Labview and I hope some of you can give some hints on how to do the task, or even if it’s not possible to do so.  My temperatures are measured by a 2 x SCC-TC02 modules and my strain are measured though a SCC-SG24 which work individually.  Pls check the program which is attached and suggest. Anything is welcome.  DanS
(3,438 Views)
Accepted by topic author DanSS
Hi DanS,
Thanks for the post!
So on every counted edge of the encoder you want to trigger the DAQ for other tasks?
If so, I have the perfect example - see attachments.
If not, could you please explain the problem again...
Kind Regards,
*edit, forgot to mention you would need to add triggering, using the DAQmx trigger node
Message Edited by Hillman on 10-21-2008 02:00 PM
Kind Regards
James Hillman
Applications Engineer 2008 to 2009 National Instruments UK & Ireland
Loughborough University UK - 2006 to 2011
Remember Kudos those who help! 😉
(3,416 Views)
 First of all thanks for the example, which helped a lot. We have tried to set of more channels, and it seams to work(2 x temp & 1 x strain from Measurement And Automation (NiMax)). One thing we haven’t quite figured out yet is how to remove the max number of counts (buffer size)?? I have attached the modified and if someone has a good proposition on to how we make that infinity, please let us know. All suggestions we be appreciated. The labview version attached is 8.5  DanS
(3,373 Views)
Hi DanSS,
Im glad the example helped out.
Im afraid thats a limiation, you cant have an infinate buffer size!
The number of samples you require for you buffer controls this.
Why do you require this?
Kind Regards
Kind Regards
James Hillman
(3,369 Views)
