Acquire images at a set voltage (for OCT)
Hello I am currently doing a project on optical coherence tomography and the first step involves writing a labview program which can grab an image at certain voltages. I have two template programs given to me (which are below) one of which sets a voltage on an NI USB-6008 and the other captures an image from the ccd I am using. How can I create a program with these to capture an image at a certain voltage?
(3,585 Views)
Do you mean a single .vi running the two functions?
If so see attached. You have to build two parallel loops.
You will set your "data" value and then press the "capture" button.
This should work if I understood your question..
Bye
(3,576 Views)
Yes that is what I mean. How do I go about in adding the 'capture' button that is linked to the case structure?
(3,557 Views)
Go to front panel, right-click and select Boolean controls from the palette.
Choose the "OK button" control.
Rename it to Capture or set its boolean text properties (right click the button).
bye!
(3,548 Views)
How can I save the images that have been acquired to disk?
(3,538 Views)
You have to add a IMAQ vision .vi to your block diagram from the palette as attached picture.
http://zone.ni.com/reference/en-XX/help/370281P-01/imaqvision/imaq_write_file_2/#IMAQWriteJPEGFile2
Connect it with the "Image" reference wire and set  a saving path in input (File path: e.g. c:\image.jpg ).
(3,531 Views)
