Acquiring 24-bit sound with a third-party sound card... truncation issues.
I am having a very strange problem when using LabVIEW to acquire audio data via the Windows API from a Creative Professional E-MU 1616m sound card.  The goal is to acquire sound in 24-bit resolution.  When capturing sound in 16-bit mode (as set in the LabVIEW software), the E-MU 1616m behaves as expected, with a 105dB SNR and approximately -130dB noise floor, after dithering.  However, when switching to 24-bit capture mode, a very severe truncation occurs.  This sends the harmonic distortion and noise through the roof.  After investigating fairly deeply in our LabVIEW code, I am wondering what might be the problem.
I have compiled a number of screenshots which showcase the problem in more detail.
Here is a background of the experiment:
For these tests, both the analog and digital audio was generated by an Audio Precision System Two system, and was passed directly into the respective line-level or digital audio inputs.  Digital audio was tested using both coax and optical cable.  In the sound card control software, the audio was sent directly from the input channel into the WAVE IN L/R (via the Windows API, I assume).  The sampling rate for the profile was 96kHz.
The sampling rate in all LabVIEW functions was set to 96kHz.  The sample rate set in the AP Digital generator was 96kHz.
In this test, everything looks fine.  The audio input is at Full-scale for the E-mu's ADCs.  It is exhibiting expected 16-bit performance (with dithering).
Now we instruct the driver to capture sound in 24 bits.  Notice that the noise floor and THD+N go up considerably.  Effects of truncation become visible on the time-domain display.
Now we drop the input level to -20dBu.   The performance starts to look a little messy but is still acceptable.  Note, however, the high peaks on the odd harmonics.
Now we try to capture at 24 bits.  The effects of truncation are extreme at this low signal level.
Now we are at extremely low signal levels.  Individual quantization levels can be seen on the signal.  Dither is also present.  Performance is still good.
However, when increasing the resolution to 24 (which should increase the number of quantization levels), our signal is reduced to a square wave.  Obviously something is wrong.
Now on to the digital tests.  We start with full-scale.  We used an AP outputting a properly dithered 16-bit signal over an optical cable.  The soundcard is instructed to receive in 16 bit mode.  It looks good.
Using the same input, we change to 24 bit receive mode.
Now we set up the AP to output a properly dithered 24-bit signal at full-scale.  The dips in the frequency domain show us that something is wrong.
Receiving in 24-bit mode.  Same story as before.
Now we decrease the amplitude to a low level.  Well-implemented dither is shown here clearly.
However, receiving in 24-bit mode reduces the signal to a dithered square wave.
Here is the low-level signal with the AP generating a 24-bit signal.  Dither is applied, but vanishes in the e-mu 1616m.  It seems the dither level has been changed.  This is the cause of our dips from before.
And finally, we transmit and receive in 24-bits.  Here are the results.
We have achieved similar results using several of your breakout boxes and soundcards.
Attached are all screenshots, as well as the main VI (AP Test.vi) and the dependent vi's.  There are a number of SVT vi's in the project, but they can be ignored since they are not related to the problem.
Any help would be greatly appreciated.
Best Regards,
Brett Gildersleeve
(3,316 Views)
Hmmm... odd.  It seems when I change the resolution to 32 bits, it magically works.  Perhaps it is a LabVIEW issue with numeric formats...  I suppose it "likes" 16 and 32 bits, whereas it doesn't like 24 bits so much.
Well, I'm not sure WHY it works, but the fact that I can finally measure with 24 bits of resolution is nice.
(3,306 Views)
Hi Brett,
I took a look at the code you attached, but it appears that you may have left out the subvi that actually acquires the sound. When you say Windows API, I assume that you are calling a DLL at some point. How are you configuring the inputs (or what function are you using)? It could be (and this is just a guess) that when you specify 24 bits, the DLL returns the data in a very specific format. If you don't interpret the bits that are returned correctly, LabVIEW may not know what to do with them, as LabVIEW does not have a native 24-bit datatype. If there is any documentation for these function calls, our answer might there...
Just some thoughts -- thanks for posting your solution!
Charlie S.
Visit ni.com/gettingstarted for step-by-step help in setting up your system
(3,288 Views)
