Acquiring Data through serial port
I am acquiring data through a serial port. I have to acquire 25 different data packets with different headers. 22 of the packets are 90 bytes each while the remaining 3 are 30 bytes each. For example:
Packet 1: $SM123........89 (header=$SM, total bytes = 90)
Packet 1: $FG123........89 (header=$FG, total bytes = 90)
Packet n: $XY123........89 (header=$XY, total bytes = 90)
Packet n+1: $YZ123........29 (header=$YZ, total bytes = 30)
I can acquire a data packet with the same header, but can't do with all the headers.
(399 Views)
Accepted by topic author Hameed97
Hi Hameed,
Do those messages come with a (well-defined) TermChar?
Why not use that TermChar and request ALWAYS 100 bytes from VISARead?
When there is no TermChar: read just 3 bytes to receive the header ("$xy"), then read the number of bytes expected for that header…
Do you know this excellent video?
(376 Views)
I have to acquire different data packets with different data lengths and different header Bytes. For example,
packet 1: $HA123....89 (3 header bytes, total length: 90)
packet 15: $MN123....29 (3 header bytes, total length: 30)
packet 24: $YZ123....49 (3 header bytes, total length: 50)
How can I do this.
(331 Views)
Hi Hameed,
instead of high-jacking very old threads you could also answer questions in your own thread!
(315 Views)
Hi GerdW,
There is no TermChar,
"When there is no TermChar: read just 3 bytes to receive the header ("$xy"), then read the number of bytes expected for that header…"
This simple solution worked very well.
The video you mentioned is also very useful.
Hameed
(277 Views)
HI GerdW,
Yes, you are right, I should have followed my thread instead of following an old thread.
Hameed
(276 Views)
