10-09-2017 03:17 AM
Hello
I’m using the NI 6536 with SCB 68, I’ve connected them via 653X adapter, I want to acquire a digital signal generated from a pulse generator, At first I’ve connected my Input to Port0 Line 0 which correspond to input 1 in the SCB 68 device, I’m able to see my pulses on NI MAX as well as in LabView , now I want to use the PFI input instead of Port0 Line 0 but It doesn’t work and I can’t localize the cause of this issue , have you any documentation to help me configure the PFI input in NI Max and the steps that I should follow to do the job ??
I ve joined the screen shot of the signal acquired from Port 0 Line 0
Thanks in advance.
10-09-2017 04:02 AM
10-09-2017 04:05 AM
Hi
Actually I want to use my digital signal as a clock that's why I want to use a PFI pin
Best Regards
10-09-2017 04:08 AM
05-25-2020 10:20 AM
hello, have you got solution? I met the same problem with yours at NI-MAX. Can we have a discussion about the solution?
05-25-2020 01:20 PM
Hi Lemmon,
Who is "you"?
Surely we can discuss your problems with your code - as soon as you attach your VI and tell us the specific problem you are stuck with!
