Acquiring analog signal from PC mic
Hi Guys,
Is it possible to acquire a signal (audio) from a laptop mic and display it in Labview? I know this can be done with a DAQ card but I was curious if I could bypass that and just use the mic in my laptop.
Thanks.
(6,563 Views)
If you open up a block diagram and select functions>>programming>>graphics and sound>>input there is some vi's you could try including an express vi.
Hope this helps
Now Using LabVIEW 2019SP1 and TestStand 2019
(6,552 Views)
Thanks,GovBob.
Will try it and let you know if it works.
(6,545 Views)
Here is a higher level example, for LabVIEW FDS:
http://decibel.ni.com/content/docs/DOC-4834
-AK2DM
(6,528 Views)
Wow that is a nice scope. I will try and use it.
Also on more question; is it possible to set up Labview so that it can communicate with the USB port of the laptop?
I realize that this should be a separate post but any hints would be very useful.
Thanks again.
(6,517 Views)
