Acquiring analog voltage data at very high speeds
I have a USB 6259 BNC DAQ board rated at 1.25 MS/sec. I am trying to acquire data samples at the rate of at least 10 kS/sec for one channel and save the data to disk/memory. Due to the noisy nature of my signal I'd like to oversample and then filter it later. I have never written code to grab data this fast. How would I write labview code to acquire data at 1.25MS/sec? I am currently thinking of switching to continuous sampling. My concern is that the time between subsequent data samples should be maintained exactly same throughout.
I would really appreciate your guidance in this matter.
(2,473 Views)
Hi Suhas,
"My concern is that the time between subsequent data samples should be maintained exactly same throughout."
That will be done by HW and so shouldn't be a concern of you...
"How would I write labview code"
Just look at the examples coming with LabVIEW. They show how to aquire data at high data rates!
(2,464 Views)
