Acquiring current camera gain SettingS?
I would like to know if it is possible to know the current Camera Gain and Shutter Speed Settings. I m employing an IMAQ 1394 Firewire Camera for the Vision Application. Any possible solutions to the above would be most welcome.
Thanks.
(3,538 Views)
You can simpley use a property node to read them.
Christian
(3,522 Views)
Accepted by topic author BlacKSTreaK
(3,506 Views)
Also don't forget to read the manual of your camera so that you know the correct attribute name for Gain & Shutter speed Smiley Wink
Share your code and camera brand & type if you need further information.
(3,499 Views)
