Acquiring data with NI USB-6008 every time it is triggered
Hello! I'm very new to labVIEW (just started working with it yesterday) and my goal is to acquire data from de DAQ board every time it is externally triggered. I'll have a device connected to my PF10 chn that will send triggers every 1sec, and I need to record data every time it does. What I was able to do so far was wait for my trigger to be first read and only then start to acquire the data, but once the first trigger is in, even if I stop triggering the DAQ it keeps acquiring data. I want it to acquire data only every time it is triggered. Is there a way to do this using labVIEW?
Thank you in advance.
(2,075 Views)
Hi Teresa,
the USB6008 only allows for start triggers…
(You could start your acquisition upon trigger signal, stop the task after 0.1s, and restart the task to wait for the next trigger. This might work when the trigger signal will only occur every 1s or so…)
(2,071 Views)
Oh okay, that sounds like a good option, thanks. I was reading about dynamic and static events, does that have anything to do with this problem, could I use it to fix my problem?
Also, I was able to trigger this DAQ board consecutively with matlab, so is it a DAQ problem or a labVIEW problem?
(2,036 Views)
HI Teresa,
Events in an event structure have nothing to do with your cheap USB6008 DAQ device…
How did you "consecutively trigger the USB6008 with MATLAB"?
Again: the USB6008 only supports a start trigger as can be read in the datasheet!
(2,024 Views)
Hello, Teresa.
     If you are "very new to LabVIEW", and some LabVIEW code that you are running is not acquiring data from an NI USB-6008 every time it is triggered" (although it acquires properly using Matlab), doesn't it make sense (to you) to show us what you are doing (by attaching the LabVIEW code, preferably the VIs you are using, showing how they are connected)?  Maybe you just left out a "wire" ...
Bob Schor
(2,017 Views)
Yes, you're right, but I only have this, and I'm using arduino to trigger the DAQ board right now, but when I disconnect arduino it keeps acquiring data, and I only want it to acquire data while it's being triggered.
(1,968 Views)
Hi Teresa,
Bob asked you for code and all we got are two images, showing parts of the code…
Please attach code (VIs!), when you are asked for code!
Again I repeat: the USB6008 only supports a start trigger! After being started it will continue to acquire samples - until you stop the task. Did I mention that already in message #2?
It is even visible in your image: you configured a "start trigger" in the DAQAssistent ExpressVI!
(1,961 Views)
