Acquiring more than 8 bits digital data from PXI-6221
I am trying to acquire data and write to the disk with PXI-6221. I am using "Digital - continuous input.vi" example. I created a sample clock task and added (see attachement).
I am selecting multiple channels. If I seleck only port0 bits, it works. If I include any of port1 or port2 bits, I get error -201062: "Possible reasons selected lines do not support buffered operations"
What is the proper way to acquire data including from port1 and port2?
Thanks in advance!
(3,774 Views)
The 6221 only supports timed digital (or waveform) I/O on port 0. The other ports can only be read as software timed.
One possibility would be to read the other lines as analog inputs. After reading compare the values to a threshold to convert to a binary signal. This will be limited by the 250 kS/s aggregate sampling rate for AI.
Lynn
(3,736 Views)
Hi Lynn,
Thanks a lot for the quick reply. It is clear now.
All the best,
(3,696 Views)
