Acquiring transient signals
Dear Labview Experts
I would like to know what is the best method to acquire some transient signals (5ms period an 2Vpp). I was trying to use AI Acquire waveform VI and scanning continuously for 3 sec (in order not to miss the signal). However when I try to get that signal within that period of time I can not see it !. When I connect a direct signal from the function generator 2Vpp 5Khz there is no problem getting that signal. I have a guts feeling that I should use the trigger VI module.
Any suggestions?
Thanks in advance for any advice
David1
(2,736 Views)
Hi David,
do you see a constant signal, I mean 10v?
If yes, than I think your signal grounding isn't right.
Please check it
Mike
> Any suggestions?
> David1
(2,736 Views)
Hello Mike
Thanks for your prompt reply; I forgot to say that before I try to get this transient signal I monitor first the background level of the input signal which is almost zero then probably there is not an offset 10V signal. Because when I try to monitor this transient signal I can see the background level but no the real signal.
Today trying again to solve this problem I notice that this transient signal is there but some time is out of the window where I want to have it.
Thanks again for your advice
David
(2,736 Views)
