Acquisition of data serial
I would like an information about LabView.
I need to monitore a serial line through the C-rio and to convert this digital sign in a binary number or hexadecimal.
To convert the digital sign for binario, it's necessary store the frames in a vector (the message can be from 8 to 572 bits).
The problem is to store in the vector the bytes (the acquisition use a boolean signal).
- How can I make this?
- Do you know some VI to do this convertion?
Already thanking!
FabianoF.
Message 1 of 8
(3,619 Views)
Fabiano,
I'm not sure I understand your question, but I'll try an answer :
you need to convert a series of bytes received as a string on your serial port. There is a string to byte array function to do this conversion, as shown in the attached png.
Message Edited by chilly charly on 06-12-2005 05:19 PM
Chilly Charly    (aka CC)
Message 2 of 8
(3,604 Views)
I understood your point but that is not exactly what I need. First, I need to get a group of boolean data and store them in an array. The problem is that I´m working with boolean data , not string data.
Thanks for your help,
FabianoF
Message 3 of 8
(3,585 Views)
The LV serial tools always return an alphanumeric string.
So, do you mean that you are receiving a string composed of a series of 0 and 1 chars ?
or a string composed of hexadecimal bytes (that could be read either as ASCII chars, or as numeric bytes...) ?
Could you post an example of the received data ? and of the way you want the result displayed ?
Message 4 of 8
(3,570 Views)
The received data are inicially in hi-level, when the signal goes to low level, I consider that transition my "start bit" of the message. The message is composed of 8 bits, my problem is how can I store these bits
in an array. After acquire 8 messages, I´ll have to store them in another array. I´m sending you a picture
of what I´m trying to do.
Thanks again.
FabianoF.
Message 5 of 8
(3,559 Views)
Still no sure if I'm helping you or not !
You have to use a shift register, as in the attached simulation example, to store the bit values read at each loop iteration.
Play with the boolean button for a while (data are collected at 2 Hz) and see how it works.
Hope this helps
Message 6 of 8
(3,544 Views)
I´m sorry, but what simulation? I guess you didn´t attached the example.
Thanks.
FabianoF.
Message 7 of 8
(3,543 Views)
Hoops !
That was a busy day ! 🙂
Message 8 of 8
(3,540 Views)
