Acquisition vidéos Bandes noires
Bonjour,
Je dispose d'une Camera FLIR modéle : A6753SC qui fonctionne en Ethernet.
J'utilise NI-max pour interroger le flux.
Pour une raison que je ne connais pas quand une fait une acquisition , je visualise des bandes noir. Chose qui n'apparait pas avec l'outil du fabriquant.
Savez-vous d'où cela pourrait venir ? Y'a-t-il des paramètres à modifier pour l'éviter ?
D'avance, merci pour votre aide.
Cordialement
Message 1 of 8
(1,304 Views)
I have seen this before when the ethernet had too much traffic.
Try a dedicated ethernet connection.
Message 2 of 8
(1,270 Views)
Thanks to reply.
I have direct connection between the camera and the computer.
If it could be due to bandwidth, I will search how can I increase it and network seting.
I'll give you a feed back....
Regards
Message 3 of 8
(1,251 Views)
Hi, check this, especially the last part about black bars. Screenshots are a bit old, but the troubleshooting method should still apply:
https://knowledge.ni.com/KnowledgeArticleDetails?id=kA03q000000YM6JCAW&l=en-US
Message 4 of 8
(1,241 Views)
Hello.
Thanks for the link, I Will check
Message 5 of 8
(1,229 Views)
There is something around the Setting "AcquisitionFrameToSkip". When I put 100, I have  less Flow Stream, but no more black stripe. I had set "IncompleteBufferMode" to "Fail", to display error when something wrong appear...
I will continue To search to understand, to be able to understand what to optimize.....
Message 6 of 8
(1,218 Views)
Do you use a proper ethernet cable?
Actor Framework
Message 7 of 8
(1,215 Views)
Yes I'm Using Propoer Ethernet Cable provide by Flir...
Message 8 of 8
(1,205 Views)
