Acromag 972EN
Has Any One worked with a Acromag 972EN-400x Beofe I cant Seem to write to the data register
Mark R.
(3,645 Views)
What mode are you using, specifically? What Modbus drivers? When the failure happens, what errors do you get? What version of LabVIEW? What OS? Has this ever worked?
Mike...
Certified LabVIEW Architect
LabVIEW Champion
(3,633 Views)
Accepted by topic author markhrussell
The issue he was simply a port error.  using port 502 regardless what the manual says solves the issue for this device
Mark R
(3,592 Views)
Yes, 502 is the default modbus port.
Mike...
LabVIEW Champion
(3,586 Views)
