Action - Write
I'm using an Action module to Write data to hard drive.  The Action module is set to Input Above Threshold but the Write keeps writing irrespective of the threshold.  I only want to Write data above the thresholds and I have piles of written data below it.
Also, can I slow the Write rate down.  I only need Write data about every 250mSec.  System is going to run 24/7 and the alarm outputs are crucial, but written data is just for trending.
(3,993 Views)
It is certaily possible to do what you want. But can you post your code? It's not really possible to give specific advice without seeing what you are working with.
Mike...
Certified LabVIEW Architect
LabVIEW Champion
(3,982 Views)
Thanks, I think I've attached this right.
(3,979 Views)
Uhhh... One more point is that this is the LabVIEW forum - not the DASYLab forum...
Mike...
LabVIEW Champion
(3,968 Views)
Oops, so I should repost in the right place or do you know DasyLab enough to answer? (!)
Craig
(3,966 Views)
Sorry I don't know DASYLab at all.
Mike...
LabVIEW Champion
(3,963 Views)
