Action engine with .Net Assembly build
I have used an Action engine in my program. The actions are for TCP/IP reference open,read and close. Everything is fine if I implemnet my sequense in LabVIEW but I have to export the current code to C# using .NET Assembly
Now if I make 3 VIs for open ,read and close what shoudl I do with the reference passing between these VIs when I export it to C#. I would greatly apprecaite your help
thanks
(3,259 Views)
I'd make 3 wrapper VI's, one for each function. Simply drop the AE with the command in a new VI.
/Y
Qestit Systems
Certified-LabVIEW-Developer
(3,218 Views)
Your code runs in an runtime engine, so as long as your assembly is referenced and running (here maybe reading from port)  dont care about internal references.
(3,206 Views)
