Action to perform when closing a window?
I want to make sure an application closes the serial port it’s using when the window is closed using the red X in windows. Is there a way to perform some specific case or something similar when that button is hit before the window closes?
(410 Views)
copied from Reddit
(401 Views)
Event Structure. The event you want to use is the <This VI>->Panel Close event. This will be triggered when you try to close the window. What I usually do is use the Filter Event version (has the ? at the end of the name). I then discard the event (stopping the closing of the window), stop the loop, and then do whatever extra clean up is required after the loop. I can then use the Front Panel->Close method to close the window if so desired.
(391 Views)
