Activating Scripting on the Web Server
I found this, but can not locate Scripting on the Web Server: Configuration page
To use scripting with a Web service, you must activate the functionality on the LabVIEW Web Server. In LabVIEW, select Scripting on the Web Server: Configuration page in the Options dialog box to activate scripting on the Web Server.
http://zone.ni.com/devzone/cda/tut/p/id/7738
(3,284 Views)
Accepted by topic author Eric_LZ
it seems that scripting is activated automatically.
(3,275 Views)
Hi Eric LZ,
Depending on the version of LabVIEW you are using, different procedures must be completed in order to enable scripting.
Hope this helps, Eric!
Carlos O
(3,256 Views)
Hi Eric LZ
You are absolutely right, for LabVIEW 2009 scripting is activated automatically.
Carlos O
(3,236 Views)
