Activation of Labview for Mac OS
Hello
I've installed LabView on my Mac, but quite some features are not available, like it is still in the evaluation mode. I'm never asked to enter a license code or to activate the product and cannot find how to do this manually either (it doesn't show up under the help menu). I have also the windows version under the same license and that runs on a PC without any problems. Does anyone know how to solve this problem?
Remco
(3,994 Views)
hello,
certainly not all features are available under MAC OS X (eg. ActiveX and other windows proprietary features).
Therfeore, can you explain the problem more detailled?
 greez
sascha
(3,988 Views)
e.g. I miss the timed while loops, DAQ assistant and write to file assistant.
(3,985 Views)
Accepted by topic author remcobdeg
Timed while loops and DAQ Assistant are Windows only features.  I always use the standard file functions, so I cannot say for sure about the file assistant.
Lack of activation is a good thing.  Do not worry about missing that.
{ Soapbox mode} NI has also chosen not to support DAQmx, a number of toolkits including the State Chart module, vision, electronics simulation, and other possibly useful things, on the Mac.  The truly unfortunate thing is that some of these were developed originally on the Mac! {end Soapbox mode}
Lynn
Message Edited by johnsold on 04-27-2009 03:01 PM
(3,975 Views)
Thanks for the information
Well, probably I'll have to stick to using windows on my mac then... such a pity.
(3,970 Views)
