Active Event Case Due To PLC Signal
Hi
How can I active event case due to signal from PLC and NI OPC Servers
when I press -by the mouse- on "Send Trigger" button the program and event case -which belong to this case- activated and work normally but when I send signal via PLC the button colored but the case not activated.
How can I active case due to signal from PLC and is it possible or not.
anyone can help?!
(1,376 Views)
AFAIK, there's no way to automatically link a data binding to a value signaling or user event.
I think you have to make a loop that reads the value, and trigger the event.
Of course, lifting your architecture to another level, as recommended in the other thread, becomes more important the more you add. Eventually you'll have to do this, and it's easier to think about it in an early stage.
(1,354 Views)
