Active X bringing a graph from excel to LV
Is there a way to display an excel graph in labview. not just data but actual graph with functionality like rollover display.  I feel like this could be done with active x but im not sure how to get it done.
Triff
(2,345 Views)
Hi Triff,
It does not look like you are able to. With Excel I would recommend getting the data and regraphing it in LabVIEW. Here is another forum post that has as similar question to yours.
As for getting the data, here is an example also. You can then create a graph using LabVIEW.
Nathan B
(2,316 Views)
