ActiveCell of Excel2000 workbook from LV
I need to read the ActiveCell address from LV using ActiveX, can someone
help?
Ladislav
(2,788 Views)
There are good examples in LabVIEW.
Click to Help\Examples\Communication\ActiveX
(2,788 Views)
The Activecell is an Application-specific object, it is not available using a Workbook or Worksheet references.
From the RefNum for Excel._Application, wire up a Property:Activecell then wire that output to a Method:Address. The returned result will be a string containing the Activecell's address. Several formatting options are available.
-Michael
Michael Munroe, CLD, CTD, MCP
Automate 1M+ VI Search, Sort and Edit operations with Property Inspector 5.1, now with a new Interactive Window Manager!
Now supports full project automation using one-click custom macros or CLI.
(2,788 Views)
