ActiveX Callback Performance Problem
Hi all
I have an USB 2 CAN Converter which I controll with an activex Container element.
The Converter has to access an ECU via the CAN Calibration Protocol (CCP; Point to Point)
That means I send via the converter an 8 byte CAN message to the ECU and the ECU sends me an adequate message back. For the sending I have to use use an activex Invoke node.
The reception of an ECU message is just possible via event callback. For that I first register an activex event callback at the start of my program. I pass a reference to the displaydata(Anzeigedaten) as a user parameter of the callback.
After sending the message to the ECU I wait inside a while loop as long as the state of my displadata is receiving a CAN message(via Property node; Status 1). Then I have to setting back the property node to Status 0. Now it is possible to process the displaydata.
And so on. I send a message wit for the receive......
So far so good. Everything works fine just very slow. With other USB to CAN hardware (peak system technik, esd electronics) this works for about ten times faster. But there I work with a dll. My experience with activex is very poor. So im not sure is there a possibility to increase the speed of my labview code.
For to spell the problem out you here is a picture.
or http://www.labviewforum.de/download.php?id=2167
Thanks in advance
Baesi
(2,659 Views)
See the same message in a different thread:
http://forums.ni.com/ni/board/message?board.id=170&message.id=184603
(2,656 Views)
