ActiveX Control for OpenOffice calc?
I am having openOffice 3.2.1 and I would like to create an activeX control.
Could anybody knows about ActiveX Object for OpenOffice calc.
Message 1 of 9
(10,695 Views)
Maybe this could be interesting for you (or not): There is an example (message 10) in the French forum but with a .NET assembly . I tried the example (cell read and cell write) with openOffice 3.2 and it's working.
JM
Message 2 of 9
(10,686 Views)
Thanks for your reply.
I need the control in front pannel, so that user can see live update. Please let me know if this is possible.
Message 3 of 9
(10,678 Views)
You can check the Open Office RGT addon on LAVA if AODL supports the desired behavior.
Felix
Message 4 of 9
(10,662 Views)
Felix,
I did check, but I did not find. Report generation tool is used for templates.
Message 5 of 9
(10,634 Views)
Could you provide some more information on what exactly you are trying to accomplish?
Brandon Treece
Message 6 of 9
(10,591 Views)
Hi Treece.
See attached. I created that control with web browser. I need the same with ActiveX Control. So that I can update the cells on live.
If you are still not clear then please let me know.
Message 7 of 9
(10,581 Views)
Hi Treece,
Sorry I did not attach report spreadsheet and also I forgot to mention that you need to have openoffice in your PC in oder to run vi, which was attached in my last message.
Sashi
Message 8 of 9
(10,568 Views)
I am not familiar with the ActiveX calls in OpenOffice.  It seems like you know how to use ActiveX in LabVIEW, but I would also take a look at this link.  This is an example of using ActiveX to call Excel.  You can use this as a template for calling OpenOffice.  Unfortunately, like I said, I am not familiar with the ActiveX calls for OpenOffice.
Brandon Treece
Message 9 of 9
(10,536 Views)
