ActiveX Cotrol Image & Memory
Hi All,
I have an activeX container on my front panel that contains a MicroSoft Web
Browser Control. I've loaden an image into it using the Navigate method. I
then use the LV GetImage method on the control to retreive the image of the
control. I'm finding that every time I execute the LV method a little more
memory gets used and never released. If I get the image enough time, it
will cause Win to run out of memory.
I'm using LV6.0.2, Win2000 and IE 6.
Has anyone seen this before, or have a solution?
Denis
(2,786 Views)
I was able to reproduce this problem in 6.0.2. I tried several workarounds but none were successful. You may not be able to do this unless someone else has a good workaround.
I tested the same VI in 6.1 and did NOT have the memory problem.
Chris_Mitchell
Product Development Engineer
Certified LabVIEW Architect
(2,786 Views)
