ActiveX DLL and Variants
Hi
does anybody know if there exists a faster way to pass Arrays of doubles between VisualBasic (ActiveX DLL) and LabView? An array of doubles apears in LabView always as a variant and therefor the speed is slow.
Thanks for helping.
(3,374 Views)
The Variant really isn't going to slow down the transfer. LV arrays are not the same as VB arrays (which through COM are passed as SafeArrays). Thus to make the call, we need to create an instance of a SafeArray and copy the LV array into it (and back out if the parameter is marked in/out or out). If the array size is very large, this can get expensive. Unfortunately, if you want to access the array data in both languages, then there isn't any other solution - the data types are just different and thus require the copy.
(3,338 Views)
LabVIEW does a better job of typing .NET arrays.  Have you tried creating a .NET .dll from the ActiveX one? There's a free command line tool for this from Microsoft:
http://stackoverflow.com/questions/4284797/how-to-extract-typelib-from-a-com-exe-on-command-line
Be sure to run it as administrator.
-D
(2,943 Views)
