ActiveX Error On Child Classes - Fanuc PCDK Kit
Here is the code for my question.
I attached my (very basic) VB code with a couple of functions that work when run in VB and the fanuc help file.
I also attached a snapshot of my labview code with errors.
I can run the VB program with no problems but when I try to use the same classes in Labview I get a "class not registered" error for any of the child classes but the .dll IS registered.  I tried unregistering and re-registering the dll with no luck and even tried regtlib.
Should I write a VB wrapper for use with Labview or is there a way to use this ActiveX .dll the way it is.
Any advice is appreciated.
thanks
mike
Message 1 of 1
(3,923 Views)
