ActiveX Excel Undefined Error
Hi all,
I am learning the use of ActiveX for Excel to import a 2-D array of data into Excel, plot the imported data and name/label the graph.  I am having a problem with opening Excel using the automation open module in LabVIEW.
I get an error code 3005 whenever I run this small program, and I cannot figure out why I get this error.  I read that ActiveX sometimes needs to be manually registered, but that help post was back in 2006 on an older LabVIEW version.  I am using Windows XP Professional and LabVIEW 2012, and I am trying to communicate with Microsoft Excel 2010.  If anyone could help me solve this problem, I would very much appreciate it.
Aki
(3,402 Views)
For more information and some sample VI's and tool kits, you can go to the excel board
Joe.
"NOTHING IS EVER EASY"
(3,395 Views)
Is the error occuring at the Automation Open function? If so, I would recommend looking into this KnowledgeBase article:
-Error 3005 at Automation Open with ActiveX in LabVIEW
http://digital.ni.com/public.nsf/allkb/EA04139737569C078625752E00645518?OpenDocument
I would also recommend going to the excel board that Joe_H suggested as well.
dK
(3,371 Views)
