ActiveX Recordset Charset
I am a problem  with select to database. I use the ActiveX ADO_Recordset GetString.
The problem is with ż and ł, on my database is just, but with the select come z and l.
How is the problem?
Its work with excel.
Thank
Clecle
(3,088 Views)
I'm guessing that the ActiveX GetString method is returning ASCII. I don't think you can set/change that.
I've used the GetString method for years, but I haven had to work with unicode.
You may need to query the DB with a different method to get the unicode data:
http://ni.lithium.com/t5/LabVIEW/Database-query-of-unicode-string-returns-Ascii/m-p/1197625/highligh...
(3,080 Views)
Hi, Thanks for your reply.
I Have tested with .NET connector but I Have an Error
I don't understand who is the driver?
(3,058 Views)
