ActiveX and Labview 5.01
Could somebody help me. I need urgently some information about where I can
get a documentation regarding ActiveX classes, parameters, invokes and
property nodes.
How do I know which parametrs and classes to use in order to generate an
array in Excel format, or something similar. (Excelfile not Spreadsheet !)
I`m using Labview 5.01 under Windows 95.
(I`ve seen the example "write table to xl.vi" but I havent really
understood)
Michael
(3,428 Views)
> property nodes.
The ActiveX components are part of the application that creates
them, not a part of labview. So information on ActiveX from Excel
will have to be gained from Microsoft. Or some kind soul here.
I dont know or I would tell you.
An Excel file IS a spreadsheet, as far as I understand it.
> understood)
This
is probably what you want to use.
> Thanks
> Michael
(3,428 Views)
Wow Kevin, I think you've hit on a new level of unhelpfulness.
Michael,
For info on ActiveX, you could start at:
http://www.ni.com/support/trouble/labview/program/activex/
There are several links to go from there, including Microsoft's
ActiveX page:
http://www.microsoft.com/com/activex.asp
By the way, a LabVIEW spreadsheet file is still like a text file, with
information basically in text format. Excel saves all sorts of
formatting info which basically makes the file unreadable in text
form.
Hope this helps,
Keith Barker
On Wed, 05 Apr 2000 11:12:02 -0500, "Kevin B. Kent"
>> property nodes.
>> understood)
>This is probably what you want to use.
>> Thanks
>> Michael
(3,428 Views)
