ActiveX container disappears after vi saved and recalled
I can create a container and insert an active x object.
The vi will run but if saved and recalled the control
disappears! No other indication of a problem.
(2,538 Views)
This problem was related to the MS Forms 2.0 scrollbar. After talking to NI they recognized it as a known problem but it was not posted. The solution was to use the Microsoft Flat Scrollbar Control, version 6.0. This is fine except for the time spent looking around. It would have helped if it had been posted originally.
(2,538 Views)
