ActiveX control and tabbing
Hello All,
I have created an activex control that is based on a dialog box. This activex control is a form with edit boxes, list boxes...
that the user can tab between. The tabbing behavior works perfectly in several containers that I have tested it within. However, when I
insert this activex control into labview the tabbing doesn't work properly. When I press the tab key the ActiveX control gets the focus
rectangle drawn around it and sets the focus to the first control in the activex control. When I press the tab key again, instead of going
to the next control in the activex, it goes to the next control on the front panel.
I have set the KeyFocus property to True and have modified the front panel settings to override the system default function keys and it
still doesn't work.
Any suggestions?
JD
(2,703 Views)
ActiveX is a grandchild window of front panel. You're trying to tab through different windows.
You might try ctrl-↓. It works for cluster elements. Not sure if it works for ActiveX or not.
George Zou
http://gtoolbox.yeah.net
George Zou
(2,697 Views)
