ActiveX error from a vi called by TS
I can’t find an answer about this error
-18001; An error occurred accessing the LabVIEW ActiveX automation server.
I’m using labview 2021 and TestStand 2021 I have a huge sequence and it’s always worked fine. Now I’m receiving this kind of error every time I call a vi that uses a self-made library (except when I enable the Highlight Execution). I don’t understand way only now, since I have used that library also during the past years and nothing has never happened.
The only help I have found only is here:
https://knowledge.ni.com/KnowledgeArticleDetails?id=kA03q000001HvXcCAK&l=it-IT
But it isn’t the same error and I don’t understand the difference in using a LabView Run-Time Engine and the LabView development System.
Is there someone who has already receive an error like that or know how to debug it?
Best Regards,
Zuc
Message 1 of 1
(1,046 Views)
