ActiveX error
When trying to insert an ActiveX object (e.g. Microsoft Web browser or Calendar control) into an ActiveX container, I am receiving "Error inserting ActiveX object: unspecified error".
Any body can help me ?
Tom
(3,476 Views)
Hi Tom,
I’ve had one other instance of this same error occurring, and the fix was actually to reinstall the LabVIEW Run-Time Engine (RTE). You can download it from ni.com >> Drivers and Updates:
http://digital.ni.com/softlib.nsf/MainPage?ReadForm&node=132010_US (select LabVIEW RTE from the Software drop-down)
You’ll also want to make sure that your ActiveX controls are properly registered:
KB 1HBAMMSR: How Do I Manually Register Type Libraries, ActiveX Controls, and ActiveX Servers?
Thanks and good luck!
Kileen
(3,461 Views)
Thank you Kileen,
I repaired LV RTE and now it works.
Tom
(3,414 Views)
