ActiveX returns a Catastrophic fatal error -2147418113
ActiveX returns a Catastrophic fatal error -2147418113. ActiveX works in C++ program from vendor.
(3,532 Views)
Below are a couple of links that will explain the error you are getting. Please read the following documents and try the suggested solution:
Receiving Error -2147418113 "Catastrophic failure in xxx.vi" When Using ActiveX Server
How Does ActiveX Server Automation Differ from ActiveX Controls?
I hope this helps.
Sincerely,
Feroz
(3,532 Views)
