ActiveX
Hi!
I am trying to understand how the ActiveX works, and I am running some
tests. I am posting a file, which is ment to do something very simple - to
run file called "test". The file "test.m" contains only one command -
"peak".
When I run the posted file nothing happens. Matlab doesn't do anything (and
matlab is open), and I don't get any error messages. I tried different
combination, but it didn't quite worked.
I will appriceate if you could look at the file. Any help will be rewarded
by pint 🙂
Victor
(2,784 Views)
Victor,
no file is attached to your post ... (hope is not my browser fault)
(2,784 Views)
