Activex Event
Dear All,
I can't speak English. I'm Sorry.
Help Me.
I want to change from VB to LabVIEW.
Refer to the picture.
(LabVIEW Version 7.1)
Thank you.
(3,637 Views)
I don't know what you're trying to do from just looking at the picture. Your subject says "ActiveX Event". Are you trying to register for an ActiveX event? Have you taken a look at the LabVIEW Help on Registering and Handling .NET and ActiveX Events?
You may wish to try to post your question in your native language an try to use Google Translate to get a rough Englis translation.
Message Edited by smercurio_fc on 04-24-2010 11:30 PM
(3,609 Views)
Dear All,
"Wait On ActiveX Event From Multiple.VI" has been using the Parameter Data.
However, only in the first Pointer Data may be.
I would like to receive as much data ICount value.
But always the first data is being received
ActiveX OCX File(Event Handle)
Void eGEMRspAllECInfo(long lCount, long* plVid, BSTR* psName, BSTR* psValue, BSTR* psDefault, BSTR* psMin, BSTR* psMax, BSTR* psUnit)
This Porgram  (ex : Icount : 4)
Vid:101,Name:Equipment_Init_Conn, Value:1, Default :1, Min:, Max:, Unit:
I Want Recive data (ex : ICount : 4)
Vid:102,Name:Establish Comm, Value:10, Default :20, Min:, Max:, Unit:
Vid:103,Name:MaxSpool, Value:20, Default :20, Min:, Max:, Unit:
Vid:104,Name:WriteSpool, Value:30, Default :30, Min:, Max:, Unit:
Thank you.
Message Edited by shami on 04-25-2010 06:12 PM
(3,591 Views)
Dear All,
Thank you.
(3,574 Views)
