Activex Icon
I am updating LV7.0 old code to 8.2 and I'm having problems with the Activex Class references, some of them work and some others do not. Also I've found that some of them changed from purple to black... Could you please tell me what the difference is? Thanx
(2,908 Views)
It seems your reference has lost the link to its source during the upgrade.  Commonly, these errors can be fixed by rewiring the block diagram.  When you do rewire these, make sure you wire from the source location to the black reference - doing this the opposite manner may not work.
Janell R | Applications Engineer
(2,886 Views)
