Activex method control for pdf
Again, I can't actually test anything, but after doing a little more digging, I have another suggestion for you. Try using the SetView property with the following inputs for ViewMode:
  • "fitb"
  • "fitbh"
  • "fitwindow"
  • "fitv 0"
Again, best of luck and let us know how it turns out!
Kind Regards,
E. Sulzer
Message 11 of 12
(1,592 Views)
That did it!!! Set View and the string "fitb" works great! Thanks for the help. That was a long process to figure out something so simple. Where did you find your information? Maybe NI should put something together showing the possible input strings for each method of common activex controls.
Thanks again!
Message 12 of 12
(1,587 Views)
