Activex options greyed out
I got those same errors in VC++ but thought I was doing something wrong.  I used dependency Walker and saw two dlls not found, MSJAVA.dll(which I can get) and EFSADU.dll.  I found these dlls and attached them.
Message 11 of 13
(911 Views)
Those 2 DLLs are unlikely to be an issue. The first is an optional module used by MSHTML.DLL, and the MSHTML DLL can handle the omission of MSJAVA.DLL. The second is used for file system encryption, and I doubt that has any part in the issue here.
I would suggest going back to whoever gave you the DLL and ask them to verify its operation in, say, VB.NET.
Message 12 of 13
(897 Views)
I do Have the same problem with a third party activeX Module.
a third of the methods are greyed out and unselectable.
I noticed that all the unselectable methods are those sending results in "complex data structure" like this (I copied a description of the structure from the 3rd party activeX manual):
BOOL
present
Whether the property is present
BOOL
autoSupported
Whether auto is supported
BOOL
manualSupported
Whether manual is supported
BOOL
onOffSupported
Whether on / off is supported
BOOL
onePushSupported
Whether one push is supported
BOOL
absValSupported
Whether absolute mode is supported
BOOL
readOutSupported
Whether the property value can be read out
LONG
min
Minimum value
LONG
max
Maximum value
I regsvr32 the activex dll and put 2 extra dlls in the system32 folder...
It is as if some complex datatype could not be handled...
My config :
Windows XP sp2
labview 8.6.1
Doc-Doc
http://www.machinevision.ch
http://visionindustrielle.ch
Please take time to rate this answer
Message 13 of 13
(846 Views)
