Actor Framework 4.1 with GOOP 4.8 problems
Hi, Im running Labview 2014 f2 + GDS 4.8 + Actor Framework 4.1. When I create a simple project with with two actors (EndevoGOOP400 class provider) and a launcher vi It gets on a loop of the parent actor calling the nested actor and nested actor calling the parent. I used GOOP + Actor Framework 4.0 on Labview 2013 with no problem.
Some help?
(2,933 Views)
Accepted by topic author Evandrofoz
Solved, I was calling the wrong way.
(2,921 Views)
