Actor Framework Executable
Hello All,
I built a project based on the Actor Framework template.  The code runs well in the development environment.
I built an executable file using the application builder and it built successfully.
The issue is when I run the executable, the launcher runs and then I get a popup asking to save 3 vi's that have been changed, including the root actor core vi.
The root actor does not run at all.
Any ideas?
(1,605 Views)
Maybe try a mass compile (Tools > Advanced > Mass Compile...) on the folder where those VIs live???
LabVIEW Pro Dev & Measurement Studio Pro (VS Pro) 2019
(1,596 Views)
I will try that.  Thanks for the input.
(1,583 Views)
You might also ask over in the Actor Framework forum:  Actor Framework Discussions - NI Community
(If you do, please add a link to this thread.)
(1,568 Views)
