Actor Framework Message Maker Icons
I’d like to suggest a small change to the way the actor framework message maker works.
At present - regardless of the icon of the method for which the message class is being produced - the following VI icons are created:
Do.vi
Send <Method>.vi
<Method> Msg.ctl
How about if instead the message class takes its VI icons from the method (with the existing glyphs layered on top). So if the method icon is:
The following icons will be produced:
Do.vi
Send <Method>.vi
<Method> Msg.ctl
OK, its not gorgous and may need a bit of tweeking but I think this might make the Actor Framework quicker and more intuitive to use.
Dan
Dan
CLA
(3,527 Views)
Might be useful to bring it to the attention of the Actor Framework enthusiasts: ni.com/actorframework
_____________________________
- Cheers, Ed
(3,507 Views)
Discussion moved to
https://decibel.ni.com/content/thread/22136
Dan
CLA
(3,429 Views)
