Actor framework build 1003 error in exe
I have 2 build specifications for actor framework based project
Debug with:
- debug enabled
- fast file format disabled
- debug enabled for all source files
- additional exclusions all off
Deploy with:
- debug disabled
- fast file format enabled
- debug disabled for all source files
Debug builds and works, for deploy I see error 1003 - broken actor core when trying to start compiled application.
What is the reason of that behavior and how to fix this?
(2,621 Views)
This is the error I get:
After checking disconnect typedefs error is like this:
(2,591 Views)
After few hours of experimentation the following settings give working app with debugging disabled:
If I select disconnect type definitions it builds but throws error 1003 on exe start... No clue why.
(2,577 Views)
Add NI_AppBuilder_Logging=True token to LabVIEW.ini to generate a detailed log of the build, that might possibly give you more information about why the error is occurring. Maybe attach the log file once you have it?
Redhawk
Test Engineer at Moog Inc.
Saying "Thanks that fixed it" or "Thanks that answers my question" and not giving a Kudo or Marked Solution, is like telling your waiter they did a great job and not leaving a tip. Please, tip your waiters.
(2,575 Views)
