Adaptive view depending on what variables are chosen
Hello all!
I've been searching for a while now and I can't find anything that helps me, so I'm turning to you!
As you can see in the title, my question is quite "simple". Is it possible to have a view that changes depending on what variables that I've chosen? I added an image to show. A list of variables to the left and depending on which ones I choose, different indicators will be shown in the area to the right. Is it possible?
If so, can you point me in the direction of some examples or instructions? 🙂
Have a nice evening!
Best regards, elicom
(3,294 Views)
Group the different indicators and put each group in a different tab in a tab control.
(3,282 Views)
Accepted by topic author elicom
Hi elicom,
Yes.
You need to program whatever you want to do with your "variables"…
Your image looks like a combination of a (multicolumn) listbox left of a subpanel container showing different "views" (aka subVIs)…
(3,281 Views)
Thank you for your fast and easy reply! 🙂 Now I know how to continue for a while.
(3,271 Views)
You can also use property nodes to change the visibility of controls/indicators.
(3,258 Views)
