Add Customized ROI Tool button NIVision Palette
Dear All,
I usally use NIVision Module in order to display camera image, i use also ROI Tools Button ( cross, line, rectangle) to define Region of Interest but I would like to add a new button ( or modify a button) at this palette. Is it possible?
Thanks for your help,
(3,447 Views)
In a short way: No.
If you right-click the palette, you can find 'Visible Items/ROI Tool Button Visibility'. You can check or uncheck tool visibility but these buttons are not linked with the actual functionality. Then you end up with button for rectangle ROI which looks like a trapezoid.
If anybody found a solution to this, I would love to hear from you as well.
(3,349 Views)
